Error printing
Sometimes when trying to print I'm having this problem, it's not always, I have to close and open the program several times to finally be able to print. what can i do to solve it at once?
https://ibb.co/pwXmRkg
I could not insert the image, they are leaving the photo link with an error
Re: Error printing
and then: Insert this image in your text with this feature :
Re: Error printing
somax wrote: ↑
Fri Jun 16, 2023 9:07 am
What can i do to solve it at once?
CMS IntelliCAD
Print configuration [HP LaserJet P2035 - ENGENHARIA] not found,
default [HP LaserJet P2035 - (A4 ENGENHARIA)] was used.
You must go to your layout folder here:
Tools > Options
and search in the Paths/Files this path :
Printer configuration path
Open it to look for in this folder this file [HP Laser P2035 - ENGENHARIA]
If this file don't exist you must re-create it !
