gridline when creating a viewport
340wby
340wby
Sun Apr 23, 2023 7:20 pm
#1 by 340wby
when I create a viewport, there are like some line that look like gridlines that show on the viewport. these lines don't print, but don't turn on or off either. is there something I can do to get rid of these lines?
  • Sat Apr 29, 2023 7:57 am
