AutoCAD 2000 layout pages in Intellicad
I have a project which uses the Page feature of AutoCAD 2000 to have multiple layout pages in the same file with the model. However, when I try to open them in Intellicad I can only toggle between the 3D model and one layout page (a custom BOM sheet which has only 2D data, no 3D viewports at all). My other pages were layouts of individual parts in the model and an assembly drawing, all using multiple views of the model.
How do I pull up and work with these other pages in Intellicad?
By the way, my Intellicad is "CMS IntelliCAD 4 PE+" (V4.0.16)
Thanks!
JoeMiner,
Select View-->Workspaces from the pull-down menu.
Select Paperspace(Tilemode Off) radio button and the Active Paperspace Layout combo box should activate.
Select the name of your layout you want to view.
OK, thanks!
Yes, that allows me to bring up all the layout pages. The only problem is that all my part geometry is missing! Is it hidden somehow, or just missing because ICAD 4 handles views differently than ACAD 2000? I checked all layer and they were all on and not frozen. What do I do now?
If I have to re-insert the views, do I use "Mview" or what?
