PDF Import
Chris B
Chris B
Wed Mar 22, 2023 2:58 pm
PDF Import
#1 by Chris B
Getting the following on trying to import a PDF:
TD_Pdfimport is missing
  • Wed Mar 22, 2023 3:02 pm
sln8458
Mon May 19, 2003 11:01 pm
Re: PDF Import
#2 by sln8458
Hi Chris,
Just tried it here and all worked fine, I'm on 11.1.374.
  • Thu Mar 23, 2023 1:40 am
  • It is currently Sun Oct 11, 2026 3:05 am
