CMS IntelliCAD 11.1 PE crash after every startup
DDaniel
DDaniel
Sat Sep 17, 2022 3:00 am
#1 by DDaniel
I'm using CMS IntelliCAD 11.1 PE version.
I got a crash after a "move" command. Since then, after each start, I get an error message and the program does not start.
Crash report file module: KERNELBASE.dll
Someone has a solution to this problem?
  • Wed Mar 22, 2023 9:06 am
