  4. AutoLisp/SDS
Scale multiple objects, each about its own Center
  4. AutoLisp/SDS
martin777
martin777
Sun Mar 05, 2023 6:21 am
#1 by martin777
How to do this in Intellicad compatible lisp?
  • Sun Mar 05, 2023 6:24 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Scale multiple objects, each about its own Center
#2 by QuanNguyen
Please refer to the simple lisp, multi-scale circle, and arc object.
(defun c:scCir(/ ent i obj ss)
  (vl-load-com)
  (if (setq i -1 ss (ssget '((0 . "CIRCLE,ARC"))))
      (SETQ scaleUp (not scaleUp))
      (while (setq ent (ssname ss (setq i (1+ i))))
	(setq obj (vlax-ename->vla-object ent))
	(setq center (vla-get-center obj))
	(vla-ScaleEntity obj center (if scaleUp 2 0.5) ))      ))
  (princ))
  • Sun Mar 05, 2023 6:33 pm
Return to “AutoLisp/SDS”
