  4. AutoLisp/SDS
Retrieve the Value from Custom Drawing Properties ACAD->ICAD
  4. AutoLisp/SDS
caddhelp
caddhelp
Fri Feb 03, 2023 5:34 pm
#1 by caddhelp
is there COM or lisp equivalent to vla-get-summaryInfo.
I need to set and get Custom DWG Properties
(setq doc(vla-get-activedocument(vlax-get-acad-object)))
(vla-get-summaryInfo doc)
  • Wed Feb 22, 2023 4:57 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Retrieve the Value from Custom Drawing Properties ACAD->ICAD
#2 by QuanNguyen
It seems that has an issue when trying to get the Custom Drawing Properties by using the Lisp function vla-get-summaryInfo now.
You can use the .NET API instead.
Regards.
  • Thu Feb 23, 2023 1:12 am
caddhelp
caddhelp
#3 by caddhelp
Thank you for the replay.
Unfortunately, we can use only API that comes with the software. So, we are stuck with VBA and Lisp
  • Thu Feb 23, 2023 10:38 am
QuanNguyen
#4 by QuanNguyen
I mean the IntelliCAD .NET API, which is included in this software.
IntelliCAD NET API.png (25.56 KiB) Viewed 19741 times
  • Thu Feb 23, 2023 6:26 pm
caddhelp
caddhelp
#5 by caddhelp
I believe I need at least VS Express
  • Sat Mar 04, 2023 10:02 am
QuanNguyen
#6 by QuanNguyen
Yes, we need Visual Studio to compile,
and we can get the VS Community free from Microsoft here: https://visualstudio.microsoft.com/vs/community/
  • Sat Mar 04, 2023 7:50 pm
caddhelp
caddhelp
#7 by caddhelp
No can do. Corporate policy :( I'm not an IT
  • Tue Mar 07, 2023 4:36 pm
QuanNguyen
#8 by QuanNguyen
FYI, the latest update of CMS IntelliCAD 11.0 Premium Edition Plus (PE+) version (Build no. 11.1.395.143696) fixed this issue.
Regards.
  • Wed Apr 26, 2023 8:36 pm
Return to “AutoLisp/SDS”
