Re: Drawing a tangent between any two circles
Hi, thank you for your reply. It explains perfectly how to create/construct a tangent . I understand this method but was looking to see if there was a method similar to autocad whereby you right click to pull up a menu, click on tangent, pick a point on the first circle and click then it auto draws a line to the next circle onto which you click again and it auto joins. HOwever, I see you are a veteran user and would have already sussed it out if that were available so my question is answered so I do thank you. At least I know now for sure. (merci beaucoup?) :-)
au revoir
Richard.
