IF statement not working?
sorry for a long post.
Following on from this post
viewtopic.php?t=3294&p=10927&sid=03c35e ... 2d0#p10927
I'm trying to chage the dimensions in the blue highlighted box from mm to inches
Here is the code for the 90deg elbow dimensions
(defun EL90_SETDIM ()
	(setvar 'dimzin 0)
	(setq
		N1 (nth 3 SIZE_DIMS)
		N2 (nth 4 SIZE_DIMS)
		N6 (nth 8 SIZE_DIMS)
		N7 (nth 9 SIZE_DIMS)
		N9 (nth 11 SIZE_DIMS)
	) ;end setq
 (if (= sca "1")(SCA_TO_IMP_EL90)) ;_ end of if
; (if (= SCA "1")(SCA_TO_IMP)) ;_ end of if
  (set_tile "n1" (rtos N1 2 2))
  (set_tile "n2" (rtos N2 2 2))
  (set_tile "n3" "")
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n6" (rtos N6 2 2))
  (set_tile "n7" (rtos N7 2 2))
  (set_tile "n8" "")
  (set_tile "n9" (rtos N9 2 2))
  (set_tile "n10" "")
  (setvar 'dimzin 8)
(princ "\n------ EL90_SETDIM ---------")
(princ "\n O/D N6 = ")
(princ 	N6)
(princ "\n sca = ")
(princ 	sca)
(princ "\n scal = ")
(princ 	scal)
) ;end of EL90_SETDIM
I have replaced the 'SCA_TO_IMP' with 'SCA_TO_IMP_EL90'
Here is the code for both:
(defun SCA_TO_IMP ()
  (cond ((= SCA "1")(setq scal "0.039370"))
		(T (setq scal "25.40000"))
		) ;end of cond
  (cond ((= SCAL "1")(setq insertscal "0.039370"))
		(T (setq insertscal "1.000000"))
		) ;end of cond
) ;End SCA_TO_IMP
(defun SCA_TO_IMP_EL90 ()
		) ;end of cond
		) ;end of cond
	(setq
      N1  (* N1 (atof scal))
      N2  (* N2 (atof scal))
;      N3  (* N3 (atof scal))
;      N4  (* N4 (atof scal))
;      N5  (* N5 (atof scal))
      N6  (* N6 (atof scal))
      N7  (* N7 (atof scal))
;      N8  (* N8 (atof scal))
      N9  (* N9 (atof scal))
;      N10  (* N10 (atof scal))
	);end of setq
  (set_tile "n3" "")
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n8" "")
  (set_tile "n10" "")
  (setvar 'dimzin 8)
(princ "\n------ SCA_TO_IMP_EL90 ---------")
(princ 	N6)
(princ "\n sca = ")
(princ 	sca)
(princ 	scal)
;(princ "\n INTERSCAL =")
;(princ 	interscal)
) ;End SCA_TO_IMP_EL90
As it is sca_to_imp_el90 is ignored.
as only the princs only show EL90 setdims.
However if I remove sca_to_imp, and rename sca_to_imp_90 as sca_to_imp.
swap the ';' in the setdim code to reflect the same change the code works.
this:
; (if (= sca "1")(SCA_TO_IMP_EL90)) ;_ end of if
and
(defun SCA_TO_IMP();_EL90 ()
		) ;end of cond
		) ;end of cond
	(setq
	);end of setq
  (set_tile "n3" "")
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n8" "")
  (set_tile "n10" "")
  (setvar 'dimzin 8)
(princ 	N6)
(princ "\n sca = ")
(princ 	sca)
(princ 	scal)
;(princ 	interscal)
) ;End SCA_TO_IMP
My problem is I have 20 different setdims, each slightly different to the others so I need separate sca to imp for each.
Where am I going wrong, what have I missed/forgotten?
Any help appreciated.
Re: IF statement not working?
:shock:
sln8458 wrote:
Thu Feb 16, 2023 1:34 am
Patrick,
That was just a 'test'. just in case it worked. a gamble
In this case 'CSA' is a local variable, it could be either upper or lower case.
see here > https://blog.draftsperson.net/autolisp- ... variables/
But ....
(setq LIST_MAX 10)
(if (/= LstNdx LIST_MAX)
(do_this))
Why / before the statement = here ??? you must read Constants in your URL please for your script.
Global and local variable in python are more demanding.....
BUT I don't understand your question : "Where am I going wrong, what have I missed/forgotten?"
What is your problem?
Why do you isolate some variable in your SCA_TO_IMP_EL90 () just for EL90.
You must use the global function SCA_TO_IMP() for all dims and make the x for all variables because "" x 1 or25 is always = ""
Patrick Depoix
Architecte D.P.L.G. & Historien-chercheur en histoire de l'Architecture
SPirou4D wrote:
Thu Feb 16, 2023 3:05 am
Patrick,
My IF statement
has no impact.
When the scaling button is selected variable SCA is set to 1.
So, If the scaling button is selected, then apply the scaling factor.
change the dimension from metric to inches
#11
I think I've made some progress, though still not there :(
I have commented out (via ';') any reference to SCA_TO_IMP throughout the code.
Redefined a couple of new functions, EL90SCA_TO_IMP & EL45SCA_TO_IMP
(defun EL90SCA_TO_IMP ()
		) ;end of cond
	  (cond ((= SCA "1")(setq insertscal "0.039370"))
		) ;end of cond
  (setq
	 );end of setq
  (set_tile "n3" "")
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n8" "")
  (set_tile "n10" "")
  (setvar 'dimzin 8)
(princ "\n--")
(princ "\n------ EL90IMP_SETDIM ---------")
(princ 	N6)
(princ "\n sca = ")
(princ 	sca)
(princ 	scal)
(princ "\n insertscal = ")
(princ 	insertscal)
) ;End EL90SCA_TO_IMP
(defun EL45SCA_TO_IMP ()
		) ;end of cond
		) ;end of cond
  (setq
	 );end of setq
  (set_tile "n3" (rtos N3 2 2))
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n8" "")
  (set_tile "n10" "")
  (setvar 'dimzin 8)
(princ "\n--")
(princ "\n------ EL45IMP_SETDIM ---------")
(princ 	N6)
(princ "\n sca = ")
(princ 	sca)
(princ 	scal)
(princ 	insertscal)
) ;End EL45SCA_TO_IMP
;  (if (= SCA "1")(SCA_TO_IMP_EL90)) ;_ end of if
	(setvar 'dimzin 0)
	(setq
	) ;end setq
 (if (= SCA "1")(EL90SCA_TO_IMP)) ;_ end of if
  (set_tile "n3" "")
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n8" "")
  (set_tile "n10" "")
  (setvar 'dimzin 8)
(defun EL45_SETDIM ()
	(setvar 'dimzin 0)
  (setq
    N3 (nth 5 SIZE_DIMS)
  ) ;end setq
  (if (= SCA "1")(EL45SCA_TO_IMP)) ;_ end of if
  (set_tile "n4" "")
  (set_tile "n5" "")
  (set_tile "n8" "")
  (set_tile "n10" "")
  (setvar 'dimzin 8)
) ;end of EL45_SETDIM
Also I have changes the action tile code for TB24:
	(action_tile "tb24" 								;toggle Imperial Scale
;	"(cond ((= fred1 \"sre90_\")
;		(progn
;			(TB24_FLAG)
;			(EL90SCA_TO_IMP)
;			((= fred1 \"sre90_\")
;		(progn
;			(TB24_FLAG)
;			(EL45SCA_TO_IMP)
;		(t  (MAIN_DIM)
		(strcat
			"(TB24_FLAG)"
			"(EL90SCA_TO_IMP)"				;(EL45SCA_TO_IMP)"
		); end strcat
	); END ACTION TILE
As this code stands ALL 90 deg elbows are drawn correctly and their dimensions are displayed correctly both in metric and imperial.
However I have failed to add the EL45SCA_TI_IMP and get it to work.
As you can see I've tried 'strcat' and using a condition statement, both fail.
Can anyone point me to some reading material to try to understand my failings?
#12
Well, I think I've resolved my problem :)
All down to the Action Tile TB24 statement.
Here is my new code, note only the 90 & 45 deg elbows atm.
	"(cond
			(TB24_FLAG)
			(EL90SCA_TO_IMP)
		((= fred1 \"lre90_\")
			(TB24_FLAG)
			(EL90SCA_TO_IMP)
		((= fred1 \"3de90_\")
			(TB24_FLAG)
			(EL90SCA_TO_IMP)
		((= fred1 \"5de90_\")
			(TB24_FLAG)
			(EL90SCA_TO_IMP)
		((= fred2 \"sre45_\")
			(TB24_FLAG)
			(EL45SCA_TO_IMP)
		((= fred2 \"lre45_\")
			(TB24_FLAG)
			(EL45SCA_TO_IMP)
		((= fred2 \"3de45_\")
			(TB24_FLAG)
			(EL45SCA_TO_IMP)
		((= fred2 \"5de45_\")
			(TB24_FLAG)
			(EL45SCA_TO_IMP)
		(t (progn
			(setq newtile $key)
			(TB24_FLAG)
	); END ACTION TILE
Now to test some more before moving on to the rest!!
#13
	"(cond
		((= fred1 \"sre90_\") (progn (TB24_FLAG) (EL90SCA_TO_IMP)))
		((= fred1 \"lre90_\") (progn (TB24_FLAG) (EL90SCA_TO_IMP)))
		((= fred1 \"3de90_\") (progn (TB24_FLAG) (EL90SCA_TO_IMP)))
		((= fred1 \"5de90_\") (progn (TB24_FLAG) (EL90SCA_TO_IMP)))
		((= fred2 \"sre45_\") (progn (TB24_FLAG) (EL45SCA_TO_IMP)))
		((= fred2 \"lre45_\") (progn (TB24_FLAG) (EL45SCA_TO_IMP)))
		((= fred2 \"3de45_\") (progn (TB24_FLAG) (EL45SCA_TO_IMP)))
		((= fred2 \"5de45_\") (progn (TB24_FLAG) (EL45SCA_TO_IMP)))
		(t (progn(setq newtile $key) (TB24_FLAG)))
); END ACTION TILE
That! what is the diff between fred1 and fred 2, please?
You can write this too:
((= fred1 'sre90_') (progn (TB24_FLAG) (EL90SCA_TO_IMP)))
Patrick Depoix
#14
fred1 is the variable I used in the 90deg Elbow dialog to store bend radii selection:
SR
LR
3D
5D
And fred2 is the same but for the 45deg Elbows.
Yes, very appropriate I know :) :)
Also
That does look neater.
I am still a novice at LISP!
I write the code in a way that helps me understand, and once working I forget to comeback and tidy up :oops:
Thanks for the tip, every day is a learning day. :lol:
