SYSVAR or setting for alert box?
Posted: Sat Feb 11, 2023 6:09 pm
by rhgrafix
I'm still fine tuning my settings after upgrading to v11.1 Pro, I am getting an alert box that is
very annoying eg. I window 30 entities and use the properties dialog box to change their layer
to a layer which is frozen, this box pops up 30 times, 1 time per entity, I have to hold the
escape key down for a while while it flashes on/off. I don't know what the alert box is called
so I can't disable it, any ideas?
CMS IntelliCAD
Selected entities changed to a frozen or off layer.
BTW, where is an easy site I can put an image so I can embed it here?
-=(RH)=-
Re: SYSVAR or setting for alert box?
Posted: Sat Feb 11, 2023 8:19 pm
Hi ,
Please set the system variable LAYEROFFORFROZENNOTIFY = 0 to turn off the dialog box message.
Posted: Sat Feb 11, 2023 10:44 pm
by rhgrafix
Yes! Thank you Quan!
That worked, I had never heard of that setting before.
Where do you park your image so the URL can be used for this forum?
I tried to drag and drop a small .png file into an earlier post and it didn't work.
Thanks,
~RH~
QuanNguyen wrote: ↑
Hi ,
Posted: Sun Feb 12, 2023 2:15 am
Please refer to this :
viewtopic.php?p=6692&sid=3fc51ee0aa88dc ... 40a7#p6692
