Updated Intellicad 11.1
Posted: Tue Feb 07, 2023 1:54 pm
by Serannelo
I have today seen an update to download version 11.1 to my PC and to remove (delete/uninstall) version 11.0 (My originally purchased product) which had been working fine.
In creating a new drawing today with V11.1 I cannot give a layer a line type ie a hidden (dashed) line as opposed to a continuous line. I try to create the new line type but keep getting a message "unable to read file". I have reinstalled and done a repair to the download but to no avail. This seems pretty poor on a straightforward install. What can I be doing wrong or is there a setting I need to alter?
R
Re: Updated Intellicad 11.1
Posted: Wed Feb 08, 2023 12:35 pm
by CMS Inc
There's something that does not look standard at the installation you've done. Did you changed anything while installing our software?
Double check that you have a Documents\CMS IntelliCAD11.1x64 folder
There, you should see the "Linetypes" folder as you cans see here:
Posted: Thu Feb 16, 2023 12:39 pm
by Serannelo
All sorted. Re-installed and works perfectly.
Posted: Thu Jul 06, 2023 6:52 pm
Just see the new update: Build no. 11.1.435.145443.
https://www.intellicadms.com/download/category/37-v11-x
Posted: Tue Jul 25, 2023 3:25 pm
by JuanSanchez
Quiero aprovechar este hilo,
para instalar la actualización:
1. ¿debo desinstalar primero la versión previa existente? o lo hace el instalador de forma automática.
2. debo proteger la clave de activación de algún modo, o no es necesario, el software lo hace de forma automática.
Posted: Tue Jul 25, 2023 6:30 pm
Hi Juan Sanchez,
To update IntelliCAD software:
1. first, must uninstall the previous version.
2. You do not need to deactivate the license if updating on the same PC.
3. Download and install the latest version.
