Using COM objects and Python to Draw a Polyline
I have been trying to figure out how to use COM objects and Python to interact with IntelliCAD. I have been able to create new layers, lines and text in Intellicad with Python but I haven't been able to figure out how to draw a polyline. Here is my code:
import win32com.client
# Create an instance of IntelliCAD
icad = win32com.client.Dispatch("Icad.Application")
# Make the IntelliCAD application visible
icad.Visible = True
# Get the current document
doc = icad.ActiveDocument
print(doc.Name)
# Create a new layer
doc.Layers.Add('New Layer')
# Create points
p1 = icad.Library.CreatePoint(0, 0)
p2 = icad.Library.CreatePoint(10, 10)
p3 = icad.Library.CreatePoint(10, 0)
# Draw line
line = doc.ModelSpace.AddLine(p1, p2)
# Draw Text
text = doc.ModelSpace.AddText('Hello World', p1, 1)
# Draw Polyline
pline = doc.ModelSpace.AddPolyLine([p1, p2, p3])
All but the last line to draw a polyline works. The last line returns a 'Type mismatch' error. Any help with this is appreciated.
Re: Using COM objects and Python to Draw a Polyline
I just figured this out. I found a VBA example for creating a polyline in the IntelliCAD Developer Reference. It shows that you must use Library.CreatePoints() method rather than Library.CreatePoint(). I was able to get this to work the following python code:
 #Create Points
points = icad.Library.CreatePoints()
points.Add()
points[0].x = 0
points[0].y = 0
points.Add()
points[1].x = 10
points[1].y = 10
points.Add()
points[2].x = 10
points[2].y = 0
# Draw Polyline
pline = doc.ModelSpace.AddPolyLine(points)
