  4. VBA, . NET & IRX
editor.GetPoint from Palette (session mode) and ContextMenuStrip
  4. VBA, . NET & IRX
RaHo
RaHo
Tue Nov 03, 2020 11:07 am
#1 by RaHo
Hi all,
if I call editor.GetPoint from button work fine,
the same button has a ContextMenuStrip.
If I click ToolStripMenuItem it don't work,
then all commands don't work.
e.g.: (call from original icon)
Command: _DIST
Error: Invalid input. Please try again.
I think application not notice that ContextMenu are closed.
  • Wed Jan 25, 2023 12:12 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 9:44 am
