Block Editor problems changing properties
If I happen to forget a checkbox or I change my mind about certain properties when I make a new block, I can't fix it in BEDIT. For example, I want to change "Scale uniformly" yes/no or "Allow exploding" yes/no, it can't be done on mine. I'm using version 11 (11.0.748.137636.PE+.VC16.x64.CMS110).
Can someone else please test theirs and see if they can make those changes?
Thanks much,
-=(RH)=-
33+ years using Autocad, wanting to fully learn iCad and share my knowledge of applicable crossover info from Acad.
-=(RLH)=-
Re: Block Editor problems changing properties
I'll have to make a screen recording and send them a bug report.
sln8458 wrote:
Sat Jan 14, 2023 2:11 am
Just tried it in 11.1
While I can change the graphic elements, lines etc and redefine the insertion point. that is all.
Does not appear to be a way to change scaling/exploding etc.
It's alsmot like someone forgot to open a dialogue??
-=(RLH)=-
