I clicked inside the circle but the circle is selected
kens6878
kens6878
Sun Mar 24, 2019 8:11 am
#1 by kens6878
Not just circles, but closed shapes as well.
  • Mon Jan 02, 2023 9:17 pm
  • It is currently Sun Oct 11, 2026 6:05 am
