Trouble with extruding polylines containing arcs
I keep getting an error when trying to extrude simple closed polylines that have arcs in them. Command returns:
“Can't extrude self-intersecting curve.
1 entities removed from selection set".
I can't extrude most new closed polylines and ones that worked in v10 don’t work in v11.
There are NO self-intersecting curves in any of these.
I can make small fillets on the corners, extrude it, then SOLIDEDIT/Face/Delete the fillets or copy the polyline and
loft it but the EXTRUDE command in version 11 is broken!
Is there a bug report page I can submit this to?
Thanks!
-=(RLH)=-
Re: Trouble with extruding polylines containing arcs
QuanNguyen wrote: ↑
Mon Nov 21, 2022 6:28 pm
It works on my V11.0 PE+.
Please create a new simple polyline with an arc segment and try again.
I tried it many more times and it won't extrude if it has even 1 arc in the closed polyline.
Thanks.
-=(RLH)=-
QuanNguyen wrote: ↑
Tue Nov 22, 2022 1:47 am
Can you attach a sample drawing having the polyline that can't be extruded?
It won't let me attach the file, it keeps saying
"Error: invalid file extension test.dwg."
That comes up whether I drag and drop into the message or use the Attach Files button.
Ramon
-=(RLH)=-
QuanNguyen wrote: ↑
Tue Nov 22, 2022 6:46 pm
You can attach the zip file.
Extrusion.zip
test.zip
(10.07 KiB) Downloaded 531 times
Thanks Quan.
I was able to extrude the pline your file, attached is one I cannot extrude.
Ramon
-=(RLH)=-
Hi Ramon,
How did you create the shape in your file?
I was unable to extrude the original shape, but after I exploded and then Pedit to a closed polyline I was then able to extrude it!?
I had/have a similar problem with closed polyline shapes created by a lisp I downloaded 'Wisey's steel shapes'. It creates closed polyline shapes that 'sometimes' need to be exploded and then re-joined to be able to extrude the shape.
Not a total solution I know, but might help.
sln8458 wrote: ↑
Wed Nov 23, 2022 1:25 am
Hi Ramon,
I usually draw lines and arcs, always snapping to the ends then use JOIN and Close. It does it with any method as long as there's at least 1 arc in it. About 80-90% of them won't extrude. I can't find any difference in the ones that will and the ones that won't. In version 10 I never had that error 1 time out of 1000s of polylines I made. Even PLINES that I made in 10 won't extrude in v11. I'm stumped, I have to copy up and LOFT most of them. I never use any 3rd party software to make them.
-=(RH)=-
-=(RLH)=-
#11
sln8458 wrote: ↑
Thu Nov 24, 2022 1:12 am
Hi Ramon,
Here is a video of me creating a similar shape to your test dwg, with an arc using a NEW file created from the original Icad template.
https://www.dropbox.com/s/64f5rmp2kzst4 ... 8.avi?dl=0
It says that the video has been deleted. I believe that it works for you and others, I just don't know why it won't work for me most of the time, it has to be related to all the other glitches I'm having.
Ramon
-=(RLH)=-
#13
sln8458 wrote: ↑
Fri Nov 25, 2022 1:09 am
Sorry Ramon, yes I deleted it yesterday by mistake.
I will put it back and post a new link.
new link:
1. Are you using Windows 11? There must be something wrong with my install.
2. What did you use to record the video?
-=(RH)=-
-=(RLH)=-
