Delete imprinted entity on a solid body?
Posted: Fri Nov 11, 2022 12:42 am
by rhgrafix
does anyone know if we can delete an imprinted entity on a face of a solid body?
In Autocad I used to press Cntl /select and then delete but it doesn't work in CMS.
I wonder if it requires a .lsp ? I can draw a polyline and extrude it then subtract it,
then union a copy of the "patch" but it's a lengthy workaround.
Thanks much!
Re: Delete imprinted entity on a solid body?
Posted: Fri Nov 11, 2022 1:02 am
can you not create a cuboid to cover/overlap the imprinted area and the add that via union??
Posted: Thu Nov 17, 2022 3:22 am
by rhgrafix
sln8458 wrote: ↑
Then I would end up with a void, that's why I have to subtract a rectangle and then fill it back in.
Posted: Thu Nov 17, 2022 4:06 am
Forgive my ignorance, but how does combining 2 solids via union create a void?
Posted: Sun Dec 11, 2022 12:09 am
Hi Ramon,
Try to use the option "Body"->"Clean" of the SolidEdit command.
Cleaning solid.png (12.11 KiB) Viewed 3951 times
