Intellicad 11 PE
Posted: Fri Oct 14, 2022 10:42 am
by Serannelo
I have downloaded the free software for evaluation for my home use in drawing models which I shall then build. I need both 2D and 3D functionality. I have downloaded a 3D autocad drawing I previously drew (in autocad). I am trying to evaluate if I can move, edit, create solid objects (manipulate them around an assembly) but I cannot work out if you can or cannot. I have found the 3D positioner but it only moves an object along one axis at a time. I need the ability to move the object in one movement from say one centre spot to a corresponding centre spot (or mark) on a shaft or object. HELP!!!!
Am I trying to use the worng version of this software or even the wrong software.
Thanks in advance.
Re: Intellicad 11 PE
Posted: Fri Oct 14, 2022 1:03 pm
by kam33mitch
Thanks in advance.
If you really want to do 3D you should try 11 PE PLUS. It has 3D modelling capabilities.
