Fired up my win 10 pro laptop, same error!
So that is 3 computers, 2xwin 10 & the new win11 PC with the same issue.
Not sure how Quan doesn't get the same problem?
I've attached a copy of my vbi file.
(it's the 'BORDER - Sub SLN_ProjectDetailsShow() )
Re: DVB file
#47Hi Steven,
It works on both Win 10 and 11 too.
Please refer to the attached.
Re: DVB file
#48Hi Quan,
Once again thankyou.
Your code does work, however i can see a number of changes prior to the specific line that is causing my problem(s).
It's very clear that the problem in me and my lack of knwledge
Re: DVB file
#50Back for more help.
I have moved on to a new module, The block insert function, yes I know there is a command for this in Icad, but the person using this has NO CAD experience and is used to using this specific set of tools.
I've added the current vbi file below.
Starting here:
The code seems to work upto displaying the form for selecting the block to insert.
I can select a block and the code steps through ok using F8 untill here:
(the last line before Icad crashed is t_index = 0)
So why does Icad crash out??
What is the problem?
SteveN.
Starting here:
Public Sub SLN_BLOCKinsert()
Private Sub BlockInsert()
Dim t_SSET As SelectionSet ' was AcadSelectionSet
Dim t_FileSystem
Dim t_FileName As String
Dim t_LayerCurrent As String
Dim t_Index As Long
Call SSetDeleteAll
t_Index = 0
While t_Index < ThisDocument.Layers.Count 'was ThisDrawing.Layers.Count***************CRASH ICAD
If ((ThisDocument.Layers(t_Index).Name <> "0") And (ThisDocument.Layers(t_Index).Name <> "B") And (ThisDocument.Layers(t_Index).LayerOn = True)) Then t_LayerCurrent = ThisDocument.Layers(t_Index).Name
t_Index = t_Index + 1
SteveN.
- Attachments
- SLN-DAP-19-12-22.zip
- (101.99 KiB) Downloaded 14 times
Re: DVB file
#51Hi Steven,
Please use ActiveDocument instead of ThisDocument.
Regards.
ActiveDocument.Layers.Count
Re: DVB file
#52Thanks Quan,
changed to this:
This code works and the selected drawing is inserted, as required.
What is the difference between ThisDocument & ActiveDocument, i'm unable to find anything in the Icad help files.
Also
I've commented out the 'if' for the InsertReference for the time being as I didn't understand why it is there, when I can see the block has beeninserted into the drawing.
plus it has another chunk of code to struggle with.
changed to this:
Dim t_FileSystem
Dim t_Index As Long
Call SSetDeleteAll
t_Index = 0
While t_Index < ActiveDocument.Layers.Count 'was ThisDrawing.Layers.Count
If ((ActiveDocument.Layers(t_Index).Name <> "0") _
And (ActiveDocument.Layers(t_Index).Name <> "B") _
And (ActiveDocument.Layers(t_Index).LayerOn = True)) _
Then t_LayerCurrent = ActiveDocument.Layers(t_Index).Name
' End If
Wend
t_FileName = DAP_IBLOCK.P.Text
If (Right$(t_FileName, 1) <> "\") Then t_FileName = t_FileName + "\"
t_FileName = t_FileName + Me.N.Text
Set t_FileSystem = CreateObject("Scripting.FileSystemObject")
If (t_FileSystem.fileexists(t_FileName)) Then
If (t_LayerCurrent <> "") Then
ActiveDocument.Layers("B").LayerOn = True ' was ThisDrawing
ActiveDocument.SendCommand ("CLAYER B" + vbCr) ' was ThisDrawing
DAP_IBLOCK.hide
ActiveDocument.SendCommand ("-insert " + t_FileName + vbCr + "0,0,0" + vbCr + "1" + vbCr + "1" + vbCr + "0" + vbCr) ' was ThisDrawing
Set t_SSET = SSetCreate("DAP_BR", 8, "B")
If (t_SSET.Count = 1) Then
t_SSET.Item(0).Explode
t_SSET.Item(0).Delete
t_SSET.Delete
' If (t_SSET.Count > 0) Then
' Call InsertReference
' For t_Index = 0 To t_SSET.Count - 1
' t_SSET.Item(t_Index).Layer = t_LayerCurrent
' Next t_Index
' ThisDocument.SendCommand ("CLAYER " + t_LayerCurrent + vbCr) ' was ThisDrawing
' ActiveDocument.Layers("B").LayerOn = False ' was ThisDrawing
' ActiveDocument.SendCommand ("move" + vbCr + "P" + vbCr + vbCr + "0,0,0" + vbCr) ' was ThisDrawing
' End If
End If
End If
Else
MsgBox "This file does not exist", 16, "ERROR"
End If
' End If
Also
Re: DVB file
#53Hi Steven,
The ActiveDocument is the IntelliCAD active document object.
The ThisDocument means the same as in the past but didn't use in the current version.
(unlucky, some sample codes in official documents still use the ThisDocument, so it causes the confused for users.)
Re: DVB file
#54Thanks Quan,
So for correctness it would be better to replace 'ThisDocument' with 'ActiveDocument' in ALL code modules etc.
Re: DVB file
#55I am struggling to make progress with this, I have to accept defeat
Is anyone able to help? possibly for a fee $/£??
By help I mean take the project on to completion.
