Block Attrubutes
Posted: Sat Sep 17, 2022 10:52 am
by Jnm226@gmail.com
HI,
Using VBA, how I get attributes tag name from a block with attributes.
I need to get and set as well.
Thank you in advance if anybody knows to do it un IntelliCAD v.11
I have the same routine in AutoCAD VBA and work fine. See below part of the code in AutoCAD 2022:
If objElem.HasAttributes Then
Array1 = objElem.GetAttributes
For intCount = LBound(Array1) To UBound(Array1)
If (Array1(intCount).EntityName) = "AcDbAttribute" Then
If strNew = "NEW" Then
If Array1(intCount).TagString = "CONTRACTNUMBER" Then
If frmNewproject.txtContractnumber.Text <> "" Then Array1(intCount).TextString = frmNewproject.txtContractnumber.Text
Re: Block Attrubutes
Posted: Mon Sep 19, 2022 2:30 am
Maybe have a bug with getting/setting attributes using VBA now.
I also can't get/set an attribute value.
Regards.
Posted: Wed Sep 21, 2022 2:00 pm
by Jnm226@gmail.com
Hi, thank you.
I figured out how to set block attributes.
Below is my code, in case help someone.
Private Sub btnDataupdate_Click()
Dim attBts As IntelliCAD.Attributes
Dim ent As Object
Dim intCount, lay As Integer
'Dim cLayout As String
'Me.Hide
On Error Resume Next
For lay = 0 To ActiveDocument.Layouts.Count - 1
If ActiveDocument.Layouts.Item(lay).Name = "Model" Then
For Each ent In ActiveDocument.ModelSpace
If ent.EntityName = "BlockInsert" Then
If ent.Name = "Project Data" Then
If ent.HasAttributes Then
Set attBts = ent.GetAttributes
For intCount = 0 To attBts.Count - 1
If attBts(intCount).TagString = "REP_EMAIL" Then
attBts(intCount).TextString = frmProjectdata.repEmail.Text
If attBts(intCount).TagString = "SALESPERSON" Then
attBts(intCount).TextString = frmProjectdata.txtSalesperson.Text
If attBts(intCount).TagString = "DATE" Then
attBts(intCount).TextString = frmProjectdata.txtDate.Text
If attBts(intCount).TagString = "DRAFTER" Then
attBts(intCount).TextString = frmProjectdata.txtDrafter.Text
If attBts(intCount).TagString = "ZIPCODE" Then
attBts(intCount).TextString = frmProjectdata.txtZipcode.Text
If attBts(intCount).TagString = "APARTMENT" Then
attBts(intCount).TextString = frmProjectdata.txtApartment.Text
If attBts(intCount).TagString = "ADDRESS" Then
attBts(intCount).TextString = frmProjectdata.txtAddress.Text
If attBts(intCount).TagString = "CONTRACT-NAME" Then
attBts(intCount).TextString = frmProjectdata.txtContractname.Text
If attBts(intCount).TagString = "CONTRACTNUMBER" Then
attBts(intCount).TextString = frmProjectdata.txtContractnumber.Text
If attBts(intCount).TagString = "REV1" Then
attBts(intCount).TextString = frmProjectdata.RevBox1.Text
If attBts(intCount).TagString = "REV2" Then
attBts(intCount).TextString = frmProjectdata.RevBox2.Text
If attBts(intCount).TagString = "REV3" Then
attBts(intCount).TextString = frmProjectdata.RevBox3.Text
If attBts(intCount).TagString = "REV4" Then
attBts(intCount).TextString = frmProjectdata.RevBox4.Text
If attBts(intCount).TagString = "REV5" Then
attBts(intCount).TextString = frmProjectdata.RevBox5.Text
If attBts(intCount).TagString = "REV6" Then
attBts(intCount).TextString = frmProjectdata.RevBox6.Text
If attBts(intCount).TagString = "SET" Then
If frmProjectdata.Dset1.Value = True Then attBts(intCount).TextString = "Drawing"
If frmProjectdata.ISet1.Value = True Then attBts(intCount).TextString = "Installation"
If frmProjectdata.RSet1.Value = True Then attBts(intCount).TextString = "Record Set"
If attBts(intCount).TagString = "SHEETS" Then
attBts(intCount).TextString = frmProjectdata.Stotalbox.Text
Next intCount
Next ent
Next lay
Call UpdateSheetData ''Update data of all sheets
ActiveDocument.Regen
MsgBox ("Project Data Updated ...")
'Me.Show
regards,
End Sub '' End Update project data
Posted: Wed Sep 21, 2022 2:03 pm
by Jnm226@gmail.com
Hi, thank you.
Dim ent As Object
'Me.Hide
Next intCount
Next ent
Next lay
'Me.Show
regards,
P.D.
Instead of 'If' statement you can use 'Select Case' statement
