Re: DATAEXTRACTION
I just had a look at the Progesoft website and this is there description:
"Advanced Data Extraction - An easy-to-use wizard for Attributes and Blocks data export"
So is this the same as in Intellicad:
(Note I use the menu bar setup)
Go to Tools dropdown and select 'Extract Attributes'
Re: DATAEXTRACTION
What you mention is the ATTEXT command
What I'm referring to is the DATAEXTRACTION command
Added in Progesoft in the 2021 version of which I am attaching the brochure with the subject highlighted.
