  4. VBA, . NET & IRX
Drawing custom properties get or set
  4. VBA, . NET & IRX
Jnm226@gmail.com
Sat Sep 03, 2022 1:14 pm
Bronx, NY
#1 by Jnm226@gmail.com
Is there any way to get or set drawing custom properties using VBA?
I’m using IntelliCAD 11.
  • Mon Sep 05, 2022 7:47 pm
QuanNguyen
Sat Nov 09, 2019 6:50 pm
Re: Drawing custom properties get or set
#2 by QuanNguyen
Sorry, It seems that IntelliCAD does not support that function using VBA.
You can use the .NET API instead.
Regards.
  • Tue Sep 06, 2022 11:56 pm
Jnm226@gmail.com
Bronx, NY
#3 by Jnm226@gmail.com
Thank You, Quan.
I will try .NET API .
Jose M.
  • Wed Sep 07, 2022 6:24 am
QuanNguyen
#4 by QuanNguyen
FYI, we can use VBA to get/set custom properties in the build of 11.1.435.
  • Sun Jul 16, 2023 6:43 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 8:48 am
