Potential new user here looking to move from AutoCAD LT 13. Can someone confirm IntelliCAD is 100% compatible with .dwg files from this older version? Just want to make sure before I completely convince my workplace to approve.
Mark
Re: AutoCAD LT 2013 compatibility
#2Mark,
I've loaded drawings all the way from 2006 without problems. 100% is a scary statement without knowing the drawings but there is a 30 day free trail that should be enough to test out what you have without problems.
I used Autocad for years and the learning curve to Intellicad is not difficult and you can customize the aliases to what you are used to.
Take advantage of the trial and see for yourself. Coming from LT, you'll love the new 3D abilities.
#3Hi Mark,
Just to add that Icad can 'save as' back to release 2.5 and ALL in between.
Give the trial a go, you will be please and frustrated in equal measure
I've used Icad since the first version released by Visio (Intellicad 98) and it's cheaper now than when I made my first purchase.
