License management - Need to transfer a license - All activations used up notice
Posted: Fri Aug 12, 2022 5:17 am
To transfer or release a CMS IntelliCAD license (version 8.2 or later), deactivate it using the License Manager (Help menu) on the currently licensed system.
Before transferring a software license to a new system, users must first deactivate the license on the currently licensed system. Users also need to hold a backup copy of the licensed version installer file.
1) at the latest licensed system, run CMS IntelliCAD
2) go to HELP menu > License Manager
3) check that you see "old site" label at the registration window
4) insert the activation key > push DEACTIVATE button
If needed, also refer to the activation/registration & deactivation Instructions available at the DOWNLOAD section of https://www.intellicadms.com
EULA terms reminder: Having trouble with your CMS IntelliCAD license? If you can't deactivate it on your old system and can't reactivate it on a new one, don't worry! You can get back to work by purchasing a support pack subscription or upgrading to the latest version
Older versions than 8.2 are not compatible with the latest Windows developments and will require a license upgrade if a license transfer (to new or formatted system) is required.
Users can upgrade their license(s) at the UPGRADES section of our online store here:
https://www.intellicadms.com/store/upgrades
