Downloaded Intellicad FV. I opened a drawing that was created using Cadopia 2k saved as a new number. When opening the newly created drawing the following error occurs. "BUFFER OVERUN THIS FILE MAYBE A AUTOCAD R14 BETA FORMAT FILE" then Intellicad bails out. This has occured more than once. Any suggestions thanks.
muncie
avaernes, Thanks for your reply. There are no solid hatches or pspace viewports. The drawing is a very simple small assembly. The problem appears to occur whenever the drawing is saved as a std r14 dwg, but not when saved as r13 or below.
muncie
[This message has been edited by muncie (edited 01-10-2001).]
muncie
Hello Munci,
Could you send a sample drawing for me to look at? It may help in determining what is going on. Just note on the email that it is for me.
Melodie
cms@etoolbox.com
Melodie
cms@etoolbox.com
