editting extruded object2
arki_emc
arki_emc
Mon Oct 27, 2003 11:01 pm
philippines
#1 by arki_emc
i cannot use subtract ang ynuion command in any extruded object that i made
  • Tue Jan 27, 2004 7:57 pm
avaernes
avaernes
Wed Oct 04, 2000 11:01 pm
Oslo, Norway
#2 by avaernes
This should be fixed with the latest product update.
  • Wed Jan 28, 2004 4:15 am
  • It is currently Sun Oct 11, 2026 1:59 am
