Whenever I launch the program, the choice warning for macro options appears.
Is it possible to memorize the choice so that, once chosen, it no longer appears? Is it possible to restore the proposed choice in the future?
Thank you
WINDOW 10 PRO
CMS Intellicad 10.1.1266.129582.PE+.VC16.x64.CMS101a
Re: START PAGE-SECURITY WARNING
#2I think it is linked to the VBA macro setting. It gives you the option in settings to turn off the VBA if you are not using it and then this pop-up won't appear. This prevents macros from running without the user knowing it. If you re-enable VBA macros the pop-up shows up again when you startup.
