  4. VBA, . NET & IRX
Irx Vs OdaTX
  4. VBA, . NET & IRX
Danielm103
Mon Aug 07, 2006 11:01 pm
Albuquerque,NM,USA
Irx Vs OdaTX
#1 by Danielm103
Looking through the API, I see headers like IcString which subclasses OdString. But all the of the samples appear to use OdString, In what cases would I want to use IcString or IcEdCommand vs OdEdCommand, IcEdSelectionSet vs OdDbSelectionSet etc?
Is one preferred over another?
Cheers :)
  • Wed Dec 15, 2021 6:47 pm
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 12:16 pm
