subtracting solid objects
arki_emc
arki_emc
Mon Oct 27, 2003 11:01 pm
philippines
#1 by arki_emc
i create a box then a dish but when i subtract the dish from the box it doesn't work....in using intellicad 4PE+ ang my os is win xp home edition....what seems to be the problem
  • Thu Oct 30, 2003 4:39 pm
joejack
joejack
Tue Sep 02, 2003 11:01 pm
Tulsa, OK USA
#2 by joejack
Welcome to the club. It's a known bug, see my topic "editing extruded solids". We're all waiting for the promised patch.
  • Fri Oct 31, 2003 8:18 am
arki_emc
arki_emc
philippines
#3 by arki_emc
yeah bro i read your topic that also my prob, added to that even solids can't be subtract
need that patch
  • Mon Nov 03, 2003 6:14 pm
  • It is currently Sun Oct 11, 2026 1:58 am
