CMS MANUFACTURING FREEBIE
ERIC
ERIC
Sun Jun 01, 2003 11:01 pm
Trollhåttan, Vås, SWEDEN
#1 by ERIC
Hi all,
I purchased 4PE+ two weeks back.
But can,t get the manufacting level 1 to work??
Can anyone help me?
Running XP home.
Oh downloaded Access as instructed from site.
Thanks in advaced,
ERIC
  • Wed Oct 01, 2003 4:28 am
  • It is currently Sun Oct 11, 2026 1:17 am
