Re: Image File Problems
have another kind of problem with images:
when I zoom in, the image disappears and it never reappears even if I do a regen. I have to save and exit and then reappear. It reappears if I change the type of graphics (BASIC <> INTERMEDIATE) but then they disappear again.
What graphics device are you using? is the graphics driver device updated? Open a new drawing, and then please run the benchmark graphics available at the CMS IntelliCAD HELP menu and report using the provided form.
What image file extension are you using , and how are you inserting the image?
I apologize, I was absent from the station.
The graphics card is: NVIDIA NVS 510
Driver 10.18.13.545 (OGL 4.5.0) 2015.10.14
I have made and sent the report: do I have to report it here as a txt attachment?
Buongiorno, ho anch'io un problema con la visualizzazione del layout. Pur impostando lo spessore dei pennini in modo corretto e differenziato, in Intellicad la linea compare di un unico spessore per tutto il disegno. Lo stesso file, visualizzato in Autocad, appare con gli spessori differenziati. Lo stesso problema c'è anche in stampa. Non so cosa devo fare. Grazie.
