AutoCAD 2004 Compatibility
PeteWhite
PeteWhite
Sat May 10, 2003 11:01 pm
West Wiltshire, UK
#1 by PeteWhite
Now that the OpenDWG Alliance has "cracked" the new AutoCAD 2004 DWG format, when are we likely to see IntelliCAD supporting Acad2004 drawings?
Pete
  • Mon Jun 30, 2003 11:17 am
  • It is currently Sun Oct 11, 2026 9:53 am
