union solid
cceab
cceab
Sat May 05, 2001 11:01 pm
Osorno
union solid
#1 by cceab
The command UNION SOLID not work when the entities are extrudes.
1. - Create two rectangles
2. - Extrude both rectangles
3. - Command UNION not work
  • Thu May 15, 2003 5:34 pm
  • It is currently Sun Oct 11, 2026 3:01 am
