That is a great site. Thanks for sharing with us. I am sure we can all benefit from your contribution.
Anyone who has not seen this site yet, go check it out there are a few very usefull lisp routines for anyone using IntelliCAD.
David Trotz
Thank you for the input. I spent a couple of hours repairing it and adding additional items. I used the path syntax you suggested and it works great.
b
avaernes, Thanks for your reply. There are no solid hatches or pspace viewports. The drawing is a very simple small assembly. The problem appears to occur whenever the drawing is saved as a std r14 dwg, but not when saved as r13 or below.
muncie
[This message has been edited by muncie (edited 01-10-2001).]
Hello!
I have the same Problems like you. But I noticed that the error occurs even with acad2000.dwg. And the error occurs not every time when you save the drawing. Maybe it belongs to the autosave-function???
