Complex Linetypes
Hector Acevedo
Hector Acevedo
Sun Sep 15, 2002 11:01 pm
Montevideo, Montevideo, Uruguay
Complex Linetypes
#1 by Hector Acevedo
Has anyone defined a complex linetype using SHAPES? I succeeded in defining complex linetypes with TEXT, but my luck run out when trying to use SHAPES. The instructions provided are not very clear. A sample will be very useful.
  • Tue Oct 08, 2002 7:56 pm
  • It is currently Sat Oct 10, 2026 9:45 pm
