CMS Intellicad PE Easy Run won't start up.
Hello!
When I go to launch PE Easy Run I see turbo.net launching it and then it just kinda disappears. No sign of it on the screen or in task manager, etc. Can't find it anywhere.
If I try again then I get the turbo error "...Currently in Use...." - which makes sense because I have launched it. But It's invisible...
I have tried clearing the memory cache as per the instruction in the FAQ section of this forum - no luck. Does the same thing.
I have un-installed PE Easy Run and Turbo sandbox manager and then rebooted - same thing. Tried that several times....
The software was working fine when I last used it a few months back. Same computer as then, etc. Running Windows 10.
Kinda stuck - Any help or suggestions would be most appreciated!
Thanks!
John
