editor.GetEntity from Palette (session mode)
Posted: Mon Jun 07, 2021 8:49 am
by RaHo
if I call "GetEntity" from COMMAND-LINE it's work
but from pallette - button not so good.
[CommandMethod("GetEntity")]
public static void GetEntity()
Document activeDoc = Application.DocumentManager.MdiActiveDocument;
Database database = activeDoc.Database;
Editor editor = activeDoc.Editor;
var result = editor.GetEntity("\nEntity");
editor.WriteMessage("\n" + result.ToString());
Re: editor.GetEntity from Palette (session mode)
Posted: Mon Jun 07, 2021 11:11 am
by DenisSilveira
May you should try something like this:
            Dim objDocument As Document = Application.DocumentManager.MdiActiveDocument
  	    Dim objEditor As Editor = objDocument.Editor
            Dim objOptions As PromptSelectionOptions = New PromptSelectionOptions()
            objOptions.MessageForAdding = vbLf & "Select lines: "
            Dim objSelectionFilter As SelectionFilter = New SelectionFilter(New TypedValue(0) {New TypedValue(CInt(DxfCode.Start), "LINE")})
            Dim objSelectionResult As PromptSelectionResult = objEditor.GetSelection(objOptions, objSelectionFilter)
            If objSelectionResult.Status <> PromptStatus.OK Then
                Return
Posted: Mon Jun 07, 2021 6:23 pm
RaHo wrote: ↑
Hi RaHo,
Can you show more detail about "not good"?
Posted: Wed Jan 25, 2023 11:46 am
by RaHo
IntelliCad 11.1 tested:
Cursor become a rectangle like original,
but then it is always there.
If I give the command "line" cursor get crosshair,
when ending cursor become a rectangle again.
From palette grafic ist preview selected
from command line not.
