Re: I'd like to know how to permanently save modified parameters value.
Thank you for reply.
First of all, the 'ZoomPercent' command doesn't seem to help.
I changed the value to a few large numbers such as 1,100, 20000 and so on, but there is no change.
Next, I looked up about changing the template file Steven told me, but I don't know what to do.
I think the file in the folder 'C:\Users\user\AppData\Roming\cms\cms intellicad 10.0 premium edition plus x64\templates' should be modified or modified in the program, can you tell me how?
Thanks for your help.
Morning Choi,
open Intellicad as normal, then:
Select file->open to open an existing drawing.
Navigate to the folder in your post above.
In the File Types to open drop-down (below file name) select 'DWT' (template files)
select Icad.dwt
once open you can make any change that you want in any future NEW drawing ie VIEWRES
this is also the place to setup your default or project standards like text font and heights|dimensions!layer names & colours etc etc
