create block
I'm trying to create a block in a lsp routine, where the 'objects' are variables from earlier in the lsp.
For some reason I am unable to add code to my posts, however
variable 1 = BV_BODY
variable 2 = BV_BALL
command "_.-Block" FLG1 "0,0,0" BV_BODY BV_BALL ""
A block is created but only contains one of the 'objects'
I've tried different name for the variables, same result.
attached zip file is an extract showing a bit more detail.
new 1.zip
(450 Bytes) Downloaded 496 times
Re: create block
Hi Steve,
You must create a selection set then add the new entities/objects to this selection set.
Refer to this routine:
(DEFUN C:CreateBlock ()
  (setq blockName "NewBlockName")
  (if (not (tblsearch "block" blockName))
      (SETQ ss (SSADD))
      (command "_circle" (list 5 5 0) 5)
      (setq eLast (entlast))
      (SSADD eLast ss)
      (command "_line" (list 0 0 0) (list 10 10 0)  "")
      (SSADD eLast ss)
      (command "_.-Block" blockName (list 5 5 0) ss "")
    (alert (strcat "Existing the block " blockName " in this drawing.\nExit!"))
(princ))
Re: create block
I already have code for the table search earlier in the code, so trimmed your code to:
(setq ss (SSADD))
(ssadd BV_BODY ss)
(ssadd BV_BALL ss)
(command "MOVE" SS "" "0,0,0" "5000,0,0" "")
I added the 'move' line to check both items were in the selection set, FAIL!
Only the BALL moved, changing the order, ie BALL first then BODY or as above makes no difference.
This is the result:
I've added a section of the lisp file to put it into perspective. The problem area is ate the end!
new 2.zip
(3.37 KiB) Downloaded 485 times
Re: create block
I managed to get this working, through a bit of a work-around.
I have 2 components that I wanted to add to a block for future insertions into the dwg.
So I created blocks of each component which were then individually inserted into the dwg and then added to the selection set.
From here I was able to create a new block of the combined blocks.
A bit of a faff but it works (see attached zip) it also bloats the drawing database/table.
new 3.zip
(1.53 KiB) Downloaded 511 times
Re: create block
Because the command "UNION" and "SUBTRACT" didn't create any NEW entity.
; CREATE BALL & SUBTRACT BORE
		(command "_sphere" (strcat "0," (rtos BCTR#) ",0") "D" BALOD# "")
		(setq RTJFBV14 (entlast))
		(command "_CYLINDER" (strcat "0," (rtos BCTR#) ",0") "D" "20.00" (+ 10.00 SPIGOT#))
		(setq RTJFBV15 (entlast))
		(command "_UNION" RTJFBV14 RTJFBV15 "")
		(setq RTJFBV16 (entlast))
		(command "_subtract" RTJFBV16 "" RTJFBV10 "")
		(setq BV_BALL (entlast))
		(command "union" RTJFBV3 RTJFBV4 RTJFBV13 "")
		(setq BV_BODY (entlast))
so the value of the variable of BV_BODY and BV_BALL is the same (the selection set has ONE entity only).
Re: create block
Thanks QuanNguyen,
I'm confused, can you explain a bit more please.
If this:
		(setq BV_BALL (entlast))does not create a new entity
does not create a new entity. WHY?
but this does:
		(command "_change" "L" "" "P" "C" "1" "")	;Red
		(command "_ROTATE" BV_BALL "" (strcat "0," (rtos BCTR#) ",0") "15")
		(setq BVBALL (entlast))
		(command "_.-Block" (strcat FLG1 "-BALL") "Y" "0,0,0" BVBALL "")
Re: create block
Try to change the color of RTJFBV16 to green and RTJFBV10 to white, then run your code (below) again.
Re: create block
#11
I'm not sure what I should be seeing?
Here is the code:
		(command "_CYLINDER" (strcat "0," (rtos BCTR#) ",0") "D" HOD# (+ 35.00 SPIGOT#))
		(command "_change" RTJFBV16 "" "P" "C" "3" "")	;GREEN			first colour applied
		(command "_change" BV_BALL "" "P" "C" "1" "")	;Red			second colour applied
		(command "_.-Block" (strcat FLG1 "-BALL") "Y" "0,0,0" BVBALL ""); finally block applied
and here is the results:
From Right to Left applying one colour at a time, and finally the Block command.
Applying the block at each colour change has no obvious impact in the result.
Re: create block
#12
Try to run this routine:
(DEFUN C:LastEntityHandle ()
  (setvar "cmdecho" 0)
  (setq BMK# 0
	BORE# 45
	BL# -250
	BCTR# 20
	BALOD# 100
	HOD# 30
	SPIGOT# 150	)
  (command "_Circle" (list 0 BMK# 0) "D" BORE# )
  (setq RTJFBV9 (entlast)) ;body I/D	2
  (command "_Extrude" RTJFBV9 "" BL# )
  (setq RTJFBV10 (entlast)) ;body I/D	2
  (command "_erase" RTJFBV9  "")
  ; ROTATE BODY O/D & I/Ds
  (command "_ROTATE3D" RTJFBV10 "" "X" (list 0 BMK# 0) "270" )
  (command "_sphere" (list 0 BCTR# 0) "D" BALOD# )
  (princ (strcat "\nEntity handle: " (cdr (assoc 5(entget RTJFBV14)))))
  (command "_CYLINDER" (list 0 BCTR# 0) "D" HOD# (+ 35.00 SPIGOT#))
  (princ (strcat "\nEntity handle: " (cdr (assoc 5(entget RTJFBV15)))))
  (princ (strcat "\nEntity handle: " (cdr (assoc 5(entget RTJFBV16)))))
  (princ (strcat "\nEntity handle: " (cdr (assoc 5(entget BV_BALL)))))
  ;(command "_ROTATE" BV_BALL "" (strcat "0," (rtos BCTR#) ",0") "15")
  (princ (strcat "\nEntity handle: " (cdr (assoc 5(entget BVBALL)))))
  ;(command "_.-Block" (strcat FLG1 "-BALL") "Y" "0,0,0" BVBALL ""); finally block applied
  (command "_change" BVBALL "" "P" "C" "4" "")
  (princ)
and see the window text
Re: create block
#13
Morning QuanNguyen,
Thanks for your help.
I copied your code, I get the same as your text window, that 4 of the 5 entities have the same handle & hence are the same.
So is this the result of an error in my code?
