Regen error
Posted: Thu May 13, 2021 8:12 am
by DenisSilveira
https://www.dropbox.com/s/5pwsd9ajhk211 ... M.mp4?dl=0
check need for regen after all operations, including simple line and erase
Re: Regen error
Posted: Sat May 15, 2021 3:05 pm
by CMS Inc
Apparently, your system has graphics device issues.
Are you using a system with 2 graphics devices? make sure to associate a suitable one with CMS IntelliCAD; Nvidia GeForce cards are recommended.
Make sure that you're running the latest build of CMS IntelliCAD 10 (check that at the HELP menu) and also that you use a suitable graphics device with CMS IntelliCAD.
Also, tweak the graphics setting using GRAPHICSCONFIG command.
Re: Regen error
Posted: Tue May 18, 2021 6:21 am
by DenisSilveira
I note files with dynamic blocks inserted or copy pasted presented this problem.
Files in these condicionts present "Errors during saving" process.
Re: Regen error
Posted: Tue May 18, 2021 10:02 am
by CMS Inc
CMS IntelliCAD does not support dynamic block edits or dynamic block insert.
Also, please send one of the .dwg files with such dynamic blocks for our review using the support contact available at https://intellicadms.com
