Layer explorer
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
Layer explorer
#1 by DenisSilveira
Try to freeze/thaw layer and explorer just "edit the name of the layer".
I can't freeze/thaw nothing.
Clicking on toolbar freeze button and selecting layer dosn't work.
Sometimes need to redraw to make changes to work .
  • Sun May 09, 2021 7:16 pm
  • It is currently Sun Oct 11, 2026 5:19 pm
