Open file dialog..... setting dxf as Standard instead of dwg
Christian
Christian
Wed May 05, 2021 11:58 pm
#1 by Christian
Is it possible to change the standard file format for PE PLUS to dxf or to make it use the last used format instead of always dwg? We get the drawing data from solidworks addon which creates sheetmetal flat patterna as dxf and use CMS PE PLUS to edit and prepare these files for cnc programming. We need dwg for a customer drawing twice a day and dxf 50-100 times.
  • Thu May 06, 2021 12:11 am
sln8458
Mon May 19, 2003 11:01 pm
Re: Open file dialog..... setting dxf as Standard instead of dwg
#2 by sln8458
Hi Christian,
I am not aware that you can change the default file type in the way you ask, however there may be a work-around.
Are you able to create a toolbar + buttons?
we could write a short script/macro to saveas (DXF) and then close or exit.
  • Thu May 06, 2021 12:44 am
Christian
Christian
#3 by Christian
Saving is not the problem.... the option what filetype to create is available. It is about opening which is always dwg and you have to change every time you open a file...
  • Thu May 06, 2021 7:01 am
QuanNguyen
Sat Nov 09, 2019 6:50 pm
#4 by QuanNguyen
Yes, the "Open file dialog for select a DXF file" can be customized by a script/macro.
But as Steve mentioned, can you able to create a toolbar + buttons?
  • Thu May 06, 2021 6:11 pm
Christian
Christian
#5 by Christian
Creating buttons or userdefined buttons or Lisp-routines ...yes
  • Fri May 07, 2021 1:13 am
Christian
Christian
#6 by Christian
I found no way to use a script or Lisp-routine to change the open file dialogue to remember .dxf instead .dwg . Bricscad as example remembers the last opened filetype. If it is possible to get it to work that way, it would be a great help.
  • Wed May 19, 2021 2:28 am
sln8458
#7 by sln8458
Hi Christian,
NOTE: use this as a 'NEW' open button 👍
try this:
(defun c:opendxf ( / sl)
(setq sl (getfiled "Pick a DXF file to open"
"E:/Stylemark Designs/"
"dxf"
10
);getfiled
);setq
(command "open" sl)
(princ)
);defun
(princ)
Change the default path to suit :)
  • Wed May 19, 2021 4:29 am
Christian
Christian
#8 by Christian
Yes , as a lisp Routine it will be useless until you have already openened another file for having your Lisp-routines autoloaded, but if you put
(getfiled "OPEN DXF" "" "dxf 10)
in the command line of the userdefined button it does exactly what we need!
Thank you very much for your support :-)
  • Wed May 19, 2021 10:18 pm
Re: jig acquire / prompt getP…
This is an interesting issue, especially since AcquirePoint() works visually with the rubber band but still doesn’t trig
merlekey, Wed Aug 12, 2026 4:04 am
Re: Purchasing 14.1 PE Plus Q…
The USB dongle option is useful for anyone who prefers a dedicated hardware license instead of managing everything digit
avan, Mon Aug 03, 2026 1:41 am
Re: Dynamic Block Look Up
Absolutely, you're on the right track—and yes, you can use the Lookup parameter in dynamic blocks to show and hid
recallvalid, Wed Jul 22, 2026 8:37 pm
Re: How to Create, Edit, and …
This is really handy. I’ve always found it a bit of a pain keeping custom textures organized, so having them saved in ar
ashegwen, Wed Jul 22, 2026 3:50 am
  • It is currently Wed Aug 26, 2026 5:07 pm
