Load LineType File
The below code can´t get line type file "Icad.lin".
The class "LInhas" returns a string with the name of linetype.
Public Shared Function DashDot() As String
        Dim sLineTypName As String = "Dashdot"
        Try
            Dim acLineTypTbl As LinetypeTable
            Dim db As Database = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database
            Dim ed As Editor = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor
            Dim path As String = HostApplicationServices.Current.FindFile("Icad.lin", db, FindFileHint.Default)
            Using tr As Transaction = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.TransactionManager.StartOpenCloseTransaction
                acLineTypTbl = tr.GetObject(IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Database.LinetypeTableId,
                                                 Teigha.DatabaseServices.OpenMode.ForRead)
                If acLineTypTbl.Has(sLineTypName) = False Then
                    Try
                        db.LoadLineTypeFile(sLineTypName, path)
                    Catch ex As Teigha.Runtime.Exception
                        If ex.ErrorStatus = ErrorStatus.FilerError Then
                            ed.WriteMessage(String.Format("Não encontrou arquivo {0}", "Icad.lin"))
                        ElseIf ex.ErrorStatus = ErrorStatus.DuplicateRecordName Then
                            ed.WriteMessage("Não pôde carregar linha existente !")
                        Else
                            ed.WriteMessage("Exceção: {0}", ex.Message)
                        End If
                        sLineTypName = "ByLayer"
                    End Try
                End If
                tr.Commit()
            End Using
        Catch ex As System.Exception
        End Try
        Return sLineTypName
    End Function
 Public Const IcadFile As String = "Icad.lin"
Dim path As String = HostApplicationServices.Current.FindFile(IcadFile, db, FindFileHint.Default)
Dim sLineTypName As String = Linhas.DashDot
                    acLineTypTbl = tr.GetObject(db.LinetypeTableId,
                        '' Load the Center Linetype
                        Try
                                ed.WriteMessage(String.Format("Não encontrou arquivo {0}", IcadFile))
                            Else
                            End If
                        End Try
                    End If
