I have a file *.dwg so I want export file to igs (iges) using vbnet
Please Help Me !!!
Re: How to export file to *.igs , *.iges using VBNEt
#3I used the send comment method but failed because it shows the name input box
Can you help me !!!
#4Hi,
Try to set the system variable "FILEDIA" =0 before send this command.
#5I have tried but it's failedQuanNguyen wrote: ↑Wed May 05, 2021 10:04 pmHi,
this is my code
Thisdrawing.SendCommand("FILEDIA" & vbCr & "0" & vbCr)
Thisdrawing.SendCommand("igesout" & vbCr & PosOutput & NameDrawing & ".igs")
Do you have FB ?
#6Hi,
Try to follow this topic viewtopic.php?f=3&t=1956&sid=7669c7f9d3 ... ab437ed276
and call the SendCommand:
activeDwg.SendCommand("FILEDIA" & vbCr & "0" & vbCr)
activeDwg.SendCommand("IGESEXPORT" & vbCr & "c:\temp\sample.igs" & vbCr & "aLL" & vbCr & vbCr)
#7I did it your way but it didn't workQuanNguyen wrote: ↑Sat May 22, 2021 12:19 amHi,
activeDwg.SendCommand("FILEDIA" & vbCr & "0" & vbCr) activeDwg.SendCommand("IGESEXPORT" & vbCr & "c:\temp\sample.igs" & vbCr & "aLL" & vbCr & vbCr)
can you try to output to igs or igse on your computer, can you help me
