  4. VBA, . NET & IRX
SetFocus
  4. VBA, . NET & IRX
DenisSilveira
DenisSilveira
Sun May 24, 2020 8:22 am
SetFocus
#1 by DenisSilveira
Is there similar function like
"Application.DocumentManager.MdiActiveDocument.Setfocus"
to set current active windows focus ?
This function exists in Autocad e is very usefull to reduce number of clicks by setting the focus to the window.
  • Sat Apr 03, 2021 7:39 am
Return to “VBA, . NET & IRX”
  • It is currently Sun Oct 11, 2026 3:38 pm
