I found this code to fillet all corners of
multiple closed polylines at the same time but it doesn't run in iCad, it just highlights the polylines and displays FMP in the text display area. I set my FILLETRAD to .05 before running it and my plines are LW.
Thanks!
(defun C:FMP ; = Fillet Multiple Polylines
(/ plss n)
(if (setq plss (ssget "_:L" '((0 . "LWPOLYLINE"))))
(repeat (setq n (sslength plss))
(command "_.fillet" "_polyline" (ssname plss (setq n (1- n))))
); repeat
); if
(princ)
); defun
33+ years using Autocad, wanting to fully learn iCad and share my knowledge of applicable crossover info from Acad.
-=(RLH)=-
