  4. New User
All layers do not appear in Layers Panel pull down
  4. New User
zeke821
zeke821
Sat Jan 16, 2021 2:39 pm
#1 by zeke821
For some reason, all available layers do not appear in the Layers Panel pull-down. What do I need to do to make them show up? They are present in Explore Layers window but not in the panel pull-down.
  • Sat Feb 27, 2021 9:54 am
sln8458
Mon May 19, 2003 11:01 pm
Re: All layers do not appear in Layers Panel pull down
#2 by sln8458
Sorry, no answer here, but I too have noticed this a number of times.
  • Mon Mar 01, 2021 2:05 am
CMS Inc
Site Admin
Wed Feb 23, 2005 12:01 am
Azle, TX
  • Facebook
  • Twitter
  • YouTube
#3 by CMS Inc
Probably an update is required.
Please review the FAQ section on how to update CMS IntelliCAD.
Also try to delete the "CMS IntelliCAD" folder that is located at your Windows documents folder.
Then run CMS IntelliCAD again, and or software will restore the folder and default files.
  • Tue Mar 02, 2021 7:05 pm
sln8458
#4 by sln8458
Apparently I have the latest release, no update available.
  • Thu Mar 04, 2021 9:49 am
Return to “New User”
  • It is currently Sun Oct 11, 2026 10:17 am
