Re: 3D Piping Menu - inserts blocks.
#16
CMS Inc wrote:
Tue Jun 01, 2021 5:28 pm
Thanks, are these files part of your app running as trial?
You might be interested in this post:
https://www.intellicad.org/articles-and ... rk-designs
Thanks for the link,
Yes these files are those required for the app, but there are no restrictions, no trial, just free :)
However if it saves people time and they want to send some money to help cover the development costs I can give Paypal details.
Question:
Could you add the files here? to save people going to Dropbox, possibly as a single zip file?
I only ask as I suspect some people will be concerned about downloading from a 3rd party website.
#17
Here is the latest files for Revision 2.1.4
I have modified the Full Bore Ball Valves and added the Reduced bore Ball Valves.
Dim Files
Piping part 1
Piping Part 2
Instructions PDF
I have deleted the files relating to the earlier version, so the links will not work.
#19
Contains 7,012 3D funneling blocks in .dwg design.
A modest option in contrast to other 3D channeling programming costing many dollars more.
Works with inch, millimeter, or feet drawing units.
As soon as possible pick the 3D channeling block you wanted from a solitary menu.
After you complete your design, run Data Extraction to make a Bill of Material.
No expectation to learn and adapt. You'll be useful in a split second.
multi-day unconditional promise.
The "3D Piping Symbols Library v2.0" is a drafting instrument to help AutoCAD 3D channeling artists and architects rapidly make 3D funneling models to produce a 2D arrangement, area, and rise drawings.
#21
Here is the latest files for Revision 2.2.1C
I have re-worked the END CAPs due to an issue with the Revolve command.
Dim Files
link deleted
Piping part 1
link deleted
Piping Part 2
link deleted
Instructions PDF (this is the PDF for version 2.1.4, please ignore the version number)
link deleted
#22
Here is the latest files for Revision 2.2.2B
Also I have modified the code for pipes to include block names to allow block listing/BOM creation.
Dim Files
link deleted
Piping part 1
link deleted
Piping Part 2
link deleted
Instructions PDF (this is the PDF for version 2.2.2B, (please ignore the version number)
link deleted
#23
(UPDATED FOR 2.3.1)
Here is the latest files for Revision 2.3.0
Following a report that the dimensions when selecting mm/inch did not convert, I have re-worked this area of code.
ALL blocks created now have the suffix 'mm' or 'inch' appened to the block name.
Dim Files
link removed
Piping part 1
link removed
Piping Part 2
link removed
Instructions PDF (this is the PDF for version 2.3.0, (please ignore the version number)
link removed
#25
Here is the latest files for Revision 2.3.2
In this version I have added fillet radii to the junction of the Main Run & Branch on both Equal & Reducing Tees.
Dim Files
link deleted
Piping part 1
link deleted
Piping Part 2
link deleted
link deleted
CMS INTELLICAD 13.1.469.162173.PE+.VC17.x64.CMS131
#26
Here is the latest files for Revision 2.3.3
I have now added/enabled the Wafer Check Valves. These Dual Plate type, and are generally in accordance with API 594
Dim Files
LINK DELETED
Piping part 1
LINK DELETED
Piping part 2
LINK DELETED
Instructions PDF
LINK DELETED
As usual, all previous links removed.
#27
Due to an error in my code, this does not work with Verion 12.1.
Updated file attched which now works.LINK DELETED
#28
Here is the latest files for Revision 2.3.3 ---- UPDATED FOR ICAD VERSION 13.0
Completed dialog.png (70.46 KiB) Viewed 8760 times
Dim Files
https://www.dropbox.com/scl/fi/ug06g5q9 ... pzqi6&dl=0
Piping part 1
https://www.dropbox.com/scl/fi/f5xtvbhj ... 1rq4l&dl=0
Piping part 2
https://www.dropbox.com/scl/fi/do2tf50j ... k39kv&dl=0
Instructions PDF
https://www.dropbox.com/scl/fi/jwfndwmz ... afom0&dl=0
