Copy text value to another entity not working
Another .lsp file that worked in Autocad 2018 but not in IntelliCAD. It doesn't give any errors, just doesn't work, pretty sure it's a syntax difference. r2.lsp should copy text value from text/mtext/& more to another entity.
Quan? Anyone? It won't let me drag n drop into here or attach .lsp extension so here it is pasted in: Thanks!
;; From msclout72 https://forums.autodesk.com/t5/user/viewprofilepage/user-id/437073
;; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/use-table-data-in-mtext-or-multileader/td-p/2568480
;;; TTC - Text to Text copy. Copy text from DIMENSION, TEXT, MTEXT, ATTRIB, ATTDEF, ACAD_TABLE to one
;; Line 212 )T?
;; Change ttc to ct then to r2, make Pair-wise the default. In a session, it remembers Continuous (Source to Multi like read Anvil) or Pair (runs like read original, long ago) ~RLH
(defun c:r2 (/ actDoc vlaObj sObj sText curObj oldForm
oType oldMode conFlag errFlag *error*)
(vl-load-com)
(setq actDoc(vla-get-ActiveDocument
(vlax-get-acad-object)))
(vla-StartUndoMark actDoc)
(defun ct_Paste(pasteStr / nslLst vlaObj hitPt
hitRes Row Column)
(setq errFlag nil)
(if
(setq nslLst(nentsel "\nPaste text >"))
(cond
(and
(= 4(length nslLst))
(= "DIMENSION"(cdr(assoc 0(entget(car(last nslLst))))))
); end and
(setq vlaObj
(vlax-ename->vla-object
(cdr(assoc -1(entget(car(last nslLst)))))))
(if
(vl-catch-all-error-p
(vl-catch-all-apply
'vla-put-TextOverride(list vlaObj pasteStr)))
(princ "\n Can't paste. Object may be on locked layer. ")
(setq errFlag T)
); end progn
); end if
); end condition #1
(and
(= "ACAD_TABLE"(cdr(assoc 0(entget(car(last nslLst))))))
); end and
(setq vlaObj
hitPt(vlax-3D-Point(trans(cadr nslLst)1 0))
hitRes(vla-HitTest vlaObj hitPt
(vlax-3D-Point '(0.0 0.0 1.0)) 'Row 'Column)
); end setq
(if(= :vlax-true hitRes)
(if
(vl-catch-all-apply
'vla-SetText(list vlaObj Row Column pasteStr)))
(setq errFlag T)
); end progn
); end if
); end progn
); end if
); end condition # 2
(and
(= "INSERT"(cdr(assoc 0(entget(car(last nslLst))))))
); end and
(princ "\nCan't paste to block's DText or MText. Select Attribute ")
(setq errFlag T)
); end condition #3
(and
(= 2(length nslLst))
(member(cdr(assoc 0(entget(car nslLst))))
'("TEXT" "MTEXT" "ATTRIB" "ATTDEF" "MULTILEADER"))
); end and
(setq vlaObj
(vlax-ename->vla-object(car nslLst)))
(if
(vl-catch-all-apply
'vla-put-TextString(list vlaObj pasteStr)))
(princ "\nError. Can't pase text. ")
(setq errFlag T)
); end progn
); end if
); end condition #4
(T
(princ "\nCan't paste. Invalid object. ")
(setq errFlag T)
); end condition #5
); end cond
T
); end progn
nil
); end if
); end of ct_Paste
(defun ct_MText_Clear(Mtext / Text Str)
(setq Text "")
(while(/= Mtext "")
(cond
((wcmatch
(strcase
(setq Str
(substr Mtext 1 2)))
(setq Mtext(substr Mtext 3)
Text(strcat Text Str)
); end setq
); end condition #1
((wcmatch(substr Mtext 1 1) "[{}]")
(setq Mtext
(substr Mtext 2))
); end condition #2
(and
(wcmatch
(strcase
(substr Mtext 1 2)) "\\P")
(/=(substr Mtext 3 1) " ")
); end and
(setq Mtext (substr Mtext 3)
Text (strcat Text " ")
); end setq
); end condition #3
((wcmatch
(strcase
(substr Mtext 1 2)) "\\[LOP]")
(setq Mtext(substr Mtext 3))
); end condition #4
((wcmatch
(strcase
(substr Mtext 1 2)) "\\[ACFHQTW]")
(setq Mtext
(substr Mtext
(+ 2
(vl-string-search ";" Mtext))))
); end condition #5
((wcmatch
(strcase (substr Mtext 1 2)) "\\S")
(setq Str(substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
Text(strcat Text (vl-string-translate "#^\\" " " Str))
Mtext(substr Mtext (+ 4 (strlen Str)))
); end setq
(print Str)
); end condition #6
(T
(setq Text(strcat Text(substr Mtext 1 1))
Mtext (substr Mtext 2)
); end condition #7
); end cond
); end while
Text
); end of ct_MText_Clear
(defun ct_Copy (/ sObj sText tType actDoc)
(if
(and
(setq sObj(car(nentsel "\nCopy text... ")))
(member(setq tType(cdr(assoc 0(entget sObj))))
'("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))
); end and
(vlax-get-Acad-object))
sText(vla-get-TextString
(vlax-ename->vla-object sObj))
); end setq
(if(= tType "MTEXT")
(setq sText(ct_MText_Clear sText))
); end if
); end progn
); end if
sText
); end of ct_Copy
(defun CCT_Str_Echo(paseStr / comStr)
(if(< 20(strlen paseStr))
(setq comStr
(strcat
(substr paseStr 1 17)"..."))
(setq comStr paseStr)
); end if
(princ
(strcat "\nText = \"" comStr "\""))
(princ)
); end of CCT_Str_Echo
(defun *error*(msg)
(vla-EndUndoMark
(princ "\nQuit ct")
(princ)
); end of *error*
(if(not ct:Mode)(setq ct:Mode "Multiple"))
(initget "Multiple Pair")
(setq oldMode ct:Mode
ct:Mode
(getkword
(strcat "\nSpecify mode [Multiple/Pair] <" ct:Mode ">: "))
conFlag T
paseStr ""
); end setq
(if(null ct:Mode)(setq ct:Mode oldMode))
(if(= ct:Mode "Multiple")
(if(and(setq paseStr(ct_Copy))conFlag)
(CCT_Str_Echo paseStr)
(while(setq conFlag(ct_Paste paseStr))T)
; end while
); end progn
); end if
); end progn
(while
(and conFlag paseStr)
(if(and paseStr conFlag)
(setq errFlag T)
(while errFlag
);end while
); end progn
); end if
); end while
); end progn
); end if
(vla-EndUndoMark actDoc)
(princ "\nQuit ct")
(princ)
); end c:ct
(princ "\n\t ct - Copy Text. Copy text from DIMENSION, TEXT, MTEXT, ATTRIB, ATTDEF, ACAD_TABLE to one")
-=(RLH)=-
Re: Copy text value to another entity not working
Hi Hamn,
Here's the modified. it accepts Text/Mtext and Dimension.
(because of some vl-* functions not work in IntelliCAD)
;; Line 212 )T?
(defun c:r2 (/ actDoc vlaObj sObj sText curObj oldForm oType oldMode conFlag errFlag *error*)
  (vl-load-com)
  (setq actDoc(vla-get-ActiveDocument(vlax-get-acad-object)))
  (defun ct_Paste(pasteStr / nslLst vlaObj hitPt hitRes Row Column)
    (setq errFlag nil)
    (if
	(cond
	  ( (and (= 4(length nslLst))
		 ); end and
	   (setq vlaObj (vlax-ename->vla-object(cdr(assoc -1(entget(car(last nslLst)))))))
	   (vla-put-TextOverride vlaObj pasteStr)
;;;	   (if
;;;	     (vl-catch-all-error-p
;;;	       (vl-catch-all-apply
;;;		 'vla-put-TextOverride(list vlaObj pasteStr)))
;;;	     (progn
;;;	       (princ "\n Can't paste. Object may be on locked layer. ")
;;;	       (setq errFlag T)
;;;	       ); end progn
;;;	     ); end if
	   ); end condition #1
;;;	  ( (and
;;;	      (= 4(length nslLst))
;;;	      (= "ACAD_TABLE"(cdr(assoc 0(entget(car(last nslLst))))))
;;;	      ); end and
;;;	   (setq vlaObj(vlax-ename->vla-object(cdr(assoc -1(entget(car(last nslLst))))))
;;;		 hitPt(vlax-3D-Point(trans(cadr nslLst)1 0))
;;;		 hitRes(vla-HitTest vlaObj hitPt
;;;			 (vlax-3D-Point '(0.0 0.0 1.0)) 'Row 'Column)
;;;		 ); end setq
;;;	   (if(= :vlax-true hitRes)
;;;	     (progn
;;;	       (if (vl-catch-all-error-p
;;;		       'vla-SetText(list vlaObj Row Column pasteStr)))
;;;		 (progn
;;;		   ); end progn
;;;		 ); end if
;;;	       ); end progn
;;;	     ); end if
;;;	   ); end condition # 2
	  ( (and
	      ); end and
	   (setq errFlag T)
	   ); end condition #3
	  ( (and
	      (princ (strcat "\n"(cdr(assoc 0(entget(car nslLst))))))
		     '("TEXT" "MTEXT")); "ATTRIB" "ATTDEF" "MULTILEADER"))
	      ); end and
	   (setq vlaObj(vlax-ename->vla-object(car nslLst)))
	   (vla-put-TextString  vlaObj pasteStr)
;;;	   (if
;;;		 'vla-put-TextString(list vlaObj pasteStr)))
;;;	     (progn
;;;	       (princ "\nError. Can't pase text. ")
;;;	       ); end progn
;;;	     ); end if
	   ); end condition #4
	  (T (princ "\nCan't paste. Invalid object. ")
	   (setq errFlag T)
	   ); end condition #5
	  ); end cond
	T
	); end progn
      nil
      ); end if
    ); end of ct_Paste
    (setq Text "")
    (while(/= Mtext "")
      (cond
	( (wcmatch(strcase(setq Str(substr Mtext 1 2)))"\\[\\{}`~]")
	       ); end setq
	 ); end condition #1
	 (setq Mtext (substr Mtext 2))
	 ); end condition #2
	( (and
	    (wcmatch(strcase(substr Mtext 1 2)) "\\P")
	    ); end and
	       ); end setq
	 ); end condition #3
	( (wcmatch(strcase(substr Mtext 1 2)) "\\[LOP]")
	 ); end condition #4
	( (wcmatch(strcase(substr Mtext 1 2)) "\\[ACFHQTW]")
	 (setq Mtext(substr Mtext(+ 2(vl-string-search ";" Mtext))))
	 ); end condition #5
	( (wcmatch (strcase (substr Mtext 1 2)) "\\S")
	       ); end setq
	 (print Str)
	 ); end condition #6
	(T (setq Text(strcat Text(substr Mtext 1 1))
	 ); end condition #7
	); end cond
      ); end while
    Text
    (if (and
		 '("TEXT" "MTEXT" "ATTRIB" "ATTDEF"))); end and
	(setq actDoc(vla-get-ActiveDocument(vlax-get-Acad-object))
	      sText(vla-get-TextString(vlax-ename->vla-object sObj))
	      ); end setq
	  ); end if
	); end progn
      ); end if
    sText
    ); end of ct_Copy
      (setq comStr(strcat(substr paseStr 1 17)"..."))
      ); end if
    (princ(strcat "\nText = \"" comStr "\""))
    (princ)
  (defun *error*(msg)
    (vla-EndUndoMark(vla-get-ActiveDocument(vlax-get-acad-object)))
    (princ "\nQuit ct")
    (princ)
    ); end of *error*
	ct:Mode(getkword(strcat "\nSpecify mode [Multiple/Pair] <" ct:Mode ">: "))
	conFlag T
	paseStr ""
	); end setq
	  ; end while
	  ); end progn
	); end if
      ); end progn
      (while (and conFlag paseStr)
	    (setq errFlag T)
	    (while errFlag
	      );end while
	    ); end progn
	  ); end if
	); end while
      ); end progn
    ); end if
  (princ "\nQuit ct")
  (princ)
  ); end c:ct
;(princ "\n\t ct - Copy Text. Copy text from DIMENSION, TEXT, MTEXT, ATTRIB, ATTDEF, ACAD_TABLE to one")
I also have this code that almost does it all, it copies values:
From/to mtext & text to mtext, text & multi-leader
From text and text attribute in block to mtext, text & multileader
but not
From text and text attribute multi-leader into block text or block attribute
If it could copy values to a block, it would be about as good as can be, is it fixable easily Quan?
Code:
;; was kopirujtext/lsp language=Czech
;; Kopie textu ze zdrojové textové entity na cílové entity (ve stejném prostoru)
;; (copy text content from a source text entity to target text entities [in the same space])
;; z www.cadforum.cz (Pajas+Hadraba)
(defun C:READ (/ sel text blky jb te s_jba at atr)
(while (not sel)
(princ "\n*** Select Source text: ")
(setq sel (entget (car (nentsel))))
(if (and (/= (cdr (assoc 0 sel)) "TEXT")
(/= (cdr (assoc 0 sel)) "MTEXT")
(/= (cdr (assoc 0 sel)) "ATTDEF")
(/= (cdr (assoc 0 sel)) "ATTRIB")
(/= (cdr (assoc 0 sel)) "MULTILEADER")
(prompt
"\n*** The selected entity is not a text, mtext, multileader or attribute."
(setq sel nil)
sel
(if (or (= (cdr (assoc 0 sel)) "TEXT")
(= (cdr (assoc 0 sel)) "MTEXT")
(= (cdr (assoc 0 sel)) "ATTRIB")
(setq text (cdr (assoc 1 sel)))
(setq text (cdr (assoc 2 sel)))
(if (= (cdr (assoc 0 sel)) "MULTILEADER")
(setq text (cdr (assoc 304 sel)))
(princ text)
(princ
"\n*** Select item to copy new text: "
(setq blky (ssget
'((-4 . "<OR")
(0 . "TEXT")
(0 . "MTEXT")
(0 . "ATTDEF")
(0 . "MULTILEADER")
(-4 . "OR>")
(setq nt 0)
(repeat (sslength blky)
(setq jb (ssname blky nt)
te (cdr (assoc '0 (entget jb)))
nt (1+ nt)
(if (or (= "TEXT" te) (= "MTEXT" te) (= "ATTDEF" te)(= "MULTILEADER" te))
(setq s_jba (append s_jba (list (list jb jb)))
;;list of entities
(princ (strcat "*** Found "
(itoa (length s_jba))
" rewritable items."
;;;Numbering
(setq nt 0)
(while (< nt (length s_jba))
(setq atr (cdr (assoc '0 (entget (cadr (nth nt s_jba))))))
(if (or (= atr "TEXT") (= atr "MTEXT"))
(setq at
(subst
(cons 1 text)
(assoc '1 (entget (cadr (nth nt s_jba))))
(if (= atr "MULTILEADER")
(setq at
(subst
(cons 304 text)
(assoc '304 (entget (cadr (nth nt s_jba))))
(setq at
(subst
(cons 2 text)
(assoc '2 (entget (cadr (nth nt s_jba))))
(entmod at)
(entupd (car (nth nt s_jba)))
(setq nt (1+ nt))
(princ)
Thanks!
QuanNguyen wrote: ↑
Mon Feb 08, 2021 7:39 pm
Hi Hamn,
Thank you for the good words.
The multi-leader object is more complex.
Regards.
-=(RLH)=-
