.NET c# send command synchron - AcDoc.Editor.Command
Hi All,
[CommandMethod("solp")]
public static void solp()
Document AcDoc = Application.DocumentManager.MdiActiveDocument;
AcadFuncVer.SwitchToModelSpace();
string CmdTxt = @"solprof all Yes No Yes Ja"; // Ja --- because german version
// AcDoc.SendStringToExecute(CmdTxt, true, true, true); it works but asyncron
AcDoc.Editor.Command(CmdTxt); // don't work
An example it need a "Return" is helpfull to.
Thanks in advance.
Re: .NET c# send command synchron - AcDoc.Editor.Command
Hi
Not sure I fully understand your idea. Please refer this example about editor.command:
        [CommandMethod("ExDrawCircleFromPoints")]
        public static void ExDrawCircleFromPoints()
            try
                Document doc = IntelliCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
                Editor ed = doc.Editor;
                Point3d oPointA = new Point3d(5.0, 5.0, 0.0);
                Point3d oPointB = new Point3d(4.5, 4.5, 0.0);
                Point3d oPointC = new Point3d(10.0, 0.0, 0.0);
                ed.Command("CIRCLE", "3P", oPointA, oPointB, oPointC);
            catch (System.Exception ex)
                System.Windows.Forms.MessageBox.Show(ex.Message);
Thanks a lot :-)
"_circle" work but see this :
[CommandMethod("ExLin")]
public static void ExDrawLine()
try
Document doc = Application.DocumentManager.MdiActiveDocument;
Point3d oPointA = new Point3d(0, 0, 0);
Point3d oPointB = new Point3d(1000, 0, 0);
ed.Command("_LINE", oPointA, oPointB);
Here you see the problem, you can not send Key like SPACE RETURN ESC
Thanks a lot.
But I have to start by "Palette Button" in sessionmode this:
If I call from command line "t123_ed" (paperspace with auto vieport)
its work correct.
OutPut:
BLOCK REC NAM : *Model_Space
BLOCK REC NAM : *Paper_Space
BLOCK REC NAM : *Paper_Space0
BLOCK REC NAM : A$2D5
LAY NAM : PV-2CF
[CommandMethod("t123_ed", CommandFlags.Session)]
public static void t0()
AcDoc.Editor.Command("t1"); // activate viewport
AcDoc.Editor.Command("t2"); // run solprof (need t1 before)
AcDoc.Editor.Command("t3"); // check created blockref and its layername
[CommandMethod("t1")]
public static void t1()
AcDoc.Editor.Command("_mspace");
[CommandMethod("t2")]
public static void t2()
Utils.ExecuteCommand("solprof", "all", " ", "Yes", "No", "Yes", " ");
[CommandMethod("t3")]
public static void t3()
Document acDoc = Application.DocumentManager.MdiActiveDocument;
Database acCurDb = acDoc.Database;
ObjectIdCollection BlkRefObjIDs = new ObjectIdCollection(), ItrObjIDs = new ObjectIdCollection();
using (Transaction acTrans = acCurDb.TransactionManager.StartTransaction())
BlockTable BlkTab = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("\n");
foreach (ObjectId BlkTabRecObjID in BlkTab)
BlockTableRecord BlkTabRec = acTrans.GetObject(BlkTabRecObjID, OpenMode.ForRead) as BlockTableRecord;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("BLOCK REC NAM : " + BlkTabRec.Name + "\n");
if (!BlkTabRec.IsLayout && !BlkTabRec.IsDynamicBlock)
ItrObjIDs = BlkTabRec.GetBlockReferenceIds(true, false);
foreach (ObjectId ItrObjID in ItrObjIDs)
BlockReference BlkRef = acTrans.GetObject(ItrObjID, OpenMode.ForRead) as BlockReference;
Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage("LAY NAM : " + BlkRef.Layer + "\n");
